Fisher & Paykel Intuitive, Fault code 37
Home Forums Public Support Forums International Forums Australasian Appliance Forum Fisher & Paykel Intuitive, Fault code 37
  • #9178
    Binks
    Can anyone help with fault code 37 on a F&P intuitive series & a fix if possible.
    Regards
    Binks
    #132852
    Re: Fisher & Paykel Intuitive, Fault code 37
    No reduction in water level detected within 30 seconds. Check for blockages, drain hose restrictions or pump failure. If nothing found check operation of water level control system.
    Binks
    Thank’s for your prompt reply, turns out problem is a 2 way diverter valve
    located after the pump on this model. Water is either pumped out, or recirculated back into the bowl. The valve operates via a wax- melt type
    piston. The problem was a breakage in the linkage between the piston and the diverter lever. The whole set up is very flimsy and bound to cause ongoing problems in this series.
    Regards
    Binks
    P.S Are the fault codes on the intuitive series the same as on smart drive machines.
    #132854
    They’ve been using the same basic codes for about 10 years now; in all honesty I’m not sure about the very latest stuff. Alexa may be able to tell you more when he’s back from his hols in a weeks time.
    CAN someone tell me how to get these FAULT CODES on the fisher& paykel w/machine 703 ,,,,sounds like,, every one comes on, knows their fault code all ready 🙄
    #132856
    Binks
    Dear guest,
    There is a procedure for getting the fault codes on a 703.
    With the machine off, (power on at the wall) press the wash temperature down button, and then the power button. all the lights will come on for a brief period. when they go off, press the spin speen up button 3 times. ( The hold and slow spin leds should both be on). The machine is now in binary fault readout mode.
    The fault codes can now be read by looking at the top row of led’s i.e spin, final rinse wash etc.
    Reading from right to left they have the following values.
    Spin = 1
    Final rinse = 2
    Rinse = 4
    3 min wash. = 8
    6 min wash = 16
    9 min wash =32
    12 min =64
    15 min = 128
    So for example if the spin light , the rinse light, and the 9 min wash light were on , and all the other lights off, that would mean a fault code of 37.
    Once you have the fault code you would need to refer to the service manual (or some-one on line) to see what that refers to.
    To return to normal operation, press the power button again.
    Hope this is of assitstance
    Regards Binks.
    javascript:emoticon(‘8)’)
  • The topic ‘Fisher & Paykel Intuitive, Fault code 37’ is closed to new replies.
