The unit starts for about 1 second and then stops numerous times until service code 43 is shown. This happens on any part of the cycle. Rinse, spin and fill. Any help would be great.
Re: Fisher & Paykel Intuitive Washing Machine – Service
Out of Balance (OOB) switch problems. These are prone to corrosion and wiring problems. Faulty suspension or bias spring disconnected can cause repeated nuisance tripping of the OOB switch, which can bring up this code.
Thanks for the tips Penguin45. I located the switch and it was corroded. I was able to get a replacement and it solved the problem. Cheapest repair you will ever do. 😆
