fisher & paykel LW035-F fault code 00101011 (43)
Home Forums Public Support Forums International Forums Australasian Appliance Forum fisher & paykel LW035-F fault code 00101011 (43)
  • #26310
    ccoutts
    Hi there,
    I’m new to this forum, primarily because I just bought a Fisher & Paykel Smartdrive washing machine (model LW035-F ) which has a problem.
    It starts the wash cycle ok (I think) by intermitantly squirting water down on the clothes, then rotating the drum, and repeating. This happens for about 1 min, then it stops, beeps, and dislays an error code: 00101011 which equates to code 43.
    I live in NZ, so rang a company called Axial who are the primary technicians and spare parts dealer for F&P whiteware in NZ. They told me it was an “Out of Balance” switch.
    Can anyone please describe where this switch is located in my machine, so I can do the standard Kiwi thing and try to fix it myself. I’ve read this post: http://www.ukwhitegoods.co.uk/modules.p … c&p=126641 which describes a few potential problems with this switch.
    Thanks for any helps
    Chris
    #209668
    Re: fisher & paykel LW035-F fault code 00101011 (43)
    43 is the OOB switch……… Top deck can be removed by undoing two screws at the back of the machine. OOB (and lid) switch both suffer from vibration and corrosion problems. You need to check function and integrity of the switch and wiring. While the top is off, ensure that the bias spring is connected to the tub in the front left corner. This prevents the tub riding against the lever. As you have recently bought it, I presume it will have been moved, so this is a distinct possibility.
    ccoutts
    Thanks Penguin45, I hoped you’d reply, as from all the other posts you seem like the guy who knows stuff!
    Thanks for your description. I’ll check them out tonight.
    Cheers
    Chris
    #209670
    ccoutts
    BTW, heres a good link I found with the schematics of all these newish machines: http://www.stokes-aus.com.au/StokesAP/i … Dryers.asp
    #209671
    Jazz
    Hey there,
    I tried to repair my switch. didnt work, so i just shorted (connected) the yellow and white wire from the switch and everything worked. No balance shut off. but if you need your machine this is a quick fix
    #209672
    Safety device – ensure that a new switch is installed at the earliest opportunity.
