Fisher & Paykel MW 053-U
  • #36905
    PAJAMAHOJO
    I have just replaced the water mixer Motor Controller.
    I have installed the new motor. The machine turns on ok from the power up button, how ever when the Start button is pushed the board shows a
    Fualt #9 …This is worked out using your sticky
    I have tried to set the size using available information. But I am having no luck
    I have run through the diagnostic process and it still indicates a code #9
    Out Back Australia Needs Your Help Please
    #252748
    Re: Fisher & Paykel MW 053-U
    PAJAMAHOJO wrote:I have had some minor success from F&P services desk.
    After replacing the Motor Module I was instructed to… Press and Hold the Start/Pause Button and Press the Power Button.
    This reset the new module and allowed it to start working. How ever I had to set the size.
    Setting the size was done while in the reset mode and is the same selection Choices as all models.
    To activate this models Diagnostic push and hold the Temp Down Button and push the Power Button, hold until the LED’S change.
    Also don’t discount that the problem could be as simple as the Hot and Cold valves. I suggest that disregarded machines are worth salvaging and using their parts to test on your machine.
    #252749
    PAJAMAHOJO
    I’m sorry I don’t understand what is ment by “Unplugged it”
    #252750
    It’s a signature, saves me typing it out every time I post. No comment intended, just moved your post to keep the threads continuity.
