Re: Fisher Paykel MW051 washer
Motor stalled. Check wiring to motor for corrosion, chaffing or just plain bad connections. Motor continuity check is a good plan. Pulsing valves can suggest problems with them, or the lid switch or out of balance mechanism, although in theory they should throw up a different code. The motor controller pcb is another prime suspect, if everything else checks out.
There are lots of 136 faults in this forum. Use Search and enter 136. Select the Oz forum only and see what else is revealed.
