I discovered on checking wiring to motor that I had an open circuit between 2 of the phases. Further investigation revealed one of the connectors had broken off the motor stator & causing a short circuit which had damaged stator beyond repair. Fortunately local spare parts guy had a 2nd hand stator ($30) which along with new position sensor ($70) had machine up & running like new.
