Fisher & Paykel MW059 no power, can’t find fuse
Home Forums Public Support Forums International Forums Australasian Appliance Forum Fisher & Paykel MW059 no power, can’t find fuse
  • #31611
    Kenton02
    Have absolutely no power.
    Does anyone know where the fuse is, or if in fact there is one?
    #231854
    bigsmokepiker
    Re: Fisher & Paykel MW059 no power, can’t find fuse
    No fuse As Such
    Check pump (The Pump is part of the power supply) if pump is open circuit
    it will have to Be replaced (Resistance Should read 33 Ohm)
    Other Than that It will be the Main PCB (Motor Controller)
    If decide to replace Controller beware
    In some instances the Water inlet coils(Valves Should Read 64Ohms)can fail & Take out the PCB
    Its all bad news im afraid (Unless Its just the Pump)
    #231855
    Kenton02
    Thanks bigsmokepiker (I think)
    Last question … where do I find the pump to test it and does 33Ohm mean it’s broken or good? [/code]
    #231856
    bigsmokepiker
    Pump is Under Bowl Of Washer
    Tilt Washer back & it will stick out like the perverable ( On the Front RHS )
    Pump Should read 33 Ohm with multimeter
