Fisher & Paykel MW511 Error on power up (00110001)
Home Forums Public Support Forums International Forums Australasian Appliance Forum Fisher & Paykel MW511 Error on power up (00110001)
  • #29176
    ledfootrob
    i turned my washing machine on today and it just started beeping at me and showed these lights 0 0 1 1 0 0 0 1 code (49) i believe
    From what I have read in other threads about this – the cold water solenoid is faulty. I checked both the coils and they both read about 60 ohms. What else can i check, are those readings ok??? Any help much appreciated. 🙁
    #222215
    Re: Fisher & Paykel MW511 Error on power up (00110001)
    Valve should read 64ohms, so you’re pretty close. Wiring harness may have dirty/oxidised/displaced connectors (common); there may be an actuation problem on the PCB.
    ledfootrob
    ok i had a look pulled it all apart seems clean etc. i pulled the plug off goin to the water solenoids should i get some sort of reading off the board when its turned on cause the multimeter is showing nothing at all.
    #222217
    Up to 24vDC for the cold valve.
