Fisher & Paykel MW511 washing machine with error code 28
Home Forums Public Support Forums International Forums Australasian Appliance Forum Fisher & Paykel MW511 washing machine with error code 28
  • #24037
    ozzman1au
    Have been all through this forum and the internet and cant find what my error code means. Im pretty sure its error no. 28. The third, fourth and fifth lights are lit on the panel. Most of the time it wont agitate or spin, on the rare occasion it will. Thanks in advance guys, looking forward to your answers.
    #200310
    Re: Fisher & Paykel MW511 washing machine with error cod
    If the lights are left to right, you’ve got 32+16+8 = 56. This is the bowl check fault. Machine may be:
    1) Overloaded, preventing the drum from floating off the drive splines.
    2) Syphoning – drain hose too far down the drain pipe – water runs in – runs straight back out again.
    3) Problem with the the motor Rotor Postion Sensor. This suffers from wiring problems, corrosion and dampness or can just plain fail.
    4) If you’re really unlucky, it’s the motor controller board. Eliminate all above problems first.
    ozzman1au
    Thanks i’ll check it out
