Re: Fisher & Paykel smart drive 501 error 00100101?
Surprisingly enough, 37 is the pump blocked code 😀 . Specifically, it means that no change in water level has been detected over a three minute period.
Check that drain hose is not kinked or trapped, if ok drain the machine and check that the pump itself is not blocked (twist fit from underneath – power OFF). Pump itself may have failed or seized (check for rusty marks/water marks); check wiring for breaks and chaffing as it turns under the drum.
