Fisher & Paykel Smart Washer 601 repeats wash cycle
Home Forums Public Support Forums International Forums Australasian Appliance Forum Fisher & Paykel Smart Washer 601 repeats wash cycle
  • #22116
    jafajones
    We have a F&P washer 601 that has recently developed a fault which results in it restarting the wash cycle after the final spin has been completed. We stop it by hitting stop/pause but when the power button is hit the 3 right lights (rinse, , Spin) come on and the machine can only be switched off at the wall.
    Appreciate any thoughts or suggestions
    Regards and thanks in anticipation
    #193722
    bigsmokepiker
    Re: Fisher & Paykel Smart Washer 601 repeats wash cycle
    Washer is in recycle feature
    To turn off
    Turn power at power point. Press &hold Wash temp down button & then power button release buttons after 2 short beeps.
    Now Use water level up button to turn recycle feature on/off
    Med water level LED ON = Recycle ON
    Med water level LED OFF= Recycle OFF
    Recycle status can be checked when you Ist turn on washer
    If last 3 lights come on =recycle ON
    if last 3 lights Off =recycle OFF
    #193723
    jafajones
    Thanks bigsmokepiker, much appreciated.
    #193724
    jafajones
    Re: Fisher & Paykel Drive 601 – repeats wash cycle
    Hi Bigsmokepiker et all, delay in response associated with the washing m/c being at our holiday location and have only just had chance to test your suggestion. (Dec/Jan is our holiday period)
    I programmed as suggested, no beep but light pattern changed after approx 2 secs.
    Changed Med water level to off per earlier advice.
    M/c works fine and switches off as expected as long as power not switched off at wall. If power to m/c lost then reverts to recycle mode and restarts at end of cycle.
    Rinse, final rinse and spin lights flash, reprogram as advised and again washer appears to work correctly until power lost for any reason.
    This is a holiday place so we will put with the problem – the m/c is probably used 20 times per year however would be great to fix.
    Appreciate any advice.
    Rgds
    Mike
