Fisher & Paykel Smartdrive 051
Home Forums Public Support Forums International Forums Australasian Appliance Forum Fisher & Paykel Smartdrive 051
  • #54010
    Kopthis
    Ok where to start, came back from holiday with the usual load of washing, the machine filled with water then it didn’t proceed, just beeped until I turned it off. I mucked around a bit, because it had done this before prior to the spin cycle, and I managed to get the machine to complete a spin cycle.
    Now however when I try to start another load it fills for a second or two then stops, tries aain about 4 or 5 times then stops and flashes the 4th light from the left whilst beeping. Tried filling with water to the low water level but it won’t proceed to the next level (again light 4 and beep), the only thin it would do was drain the water out (after manually advancing the cycle)
    Any ides???
    #318046
    Re: Fisher & Paykel Smartdrive 051
    That would be code 8 or 16 depending on which way round you’ve read the LEDs. One is only appicable to phase 1 machines (Yours is a phase 2), the other is not used.
    Have a read of the sticky at the top of the forum and run the diagnostics; see what you get.
