Fisher & Paykel Smartdrive 608 powers off intermitantly
Home Forums Public Support Forums International Forums Australasian Appliance Forum Fisher & Paykel Smartdrive 608 powers off intermitantly
  • #12122
    jericho
    I have a F&P smart drive 608 6.5kg washing machine. Just lately, when it’s been in it’s spin cyvle, the power cuts out completly, no lights, no nothing. You cannot switch it on again. Tried plugging into a different outlet etc. After a few minutes, you can switch it on again and it will work fine. This only happens intermittantly, you might be able to do 5 washes in a row and then the next one it will die. Any help would be appreciated.
    Cheers
    #147983
    Re: Fisher & Paykel Smartdrive 608 powers off intermitan
    Replace the drain pump a.s.a.p. P/n 420324p
    #147984
    FastAndPro
    608 I would go for the Module drain pump will still let the machine turn on again not a comman fault but I have seen it
    Later models Drain pump resitance less than 32 ohms replace It asap
