Fisher & Paykel smartdrive 701 error?
Home Forums Public Support Forums International Forums Australasian Appliance Forum Fisher & Paykel smartdrive 701 error?
  • #15501
    ricoda
    missus went to start the washine machine and it would just beep with the spin light flashing. i had a bit of a browse thru these forums and found how to enter diagnostics mode. it shows
    00001001 with spin, hold and high and low water level lights.
    tried pressing a few buttons and it fills with water, and regular wash button starts the pump, but then all three (rinse, final rinse and spin) red progress lights started flashing. bit more button pressing and now all the green progress lights flash, but if i restart a wash sequence it still goes back to the beeping and spin light flashing …
    WHAT have i done !!!! 🙂
    david@ricoda.com.au
    cheers Dave
    #163845
    Re: Fisher & Paykel smartdrive 701 error?
    If we go with the code you’ve got, there’s a size error fault. What you’ve done for the rest of the lights I haven’t got a clue……..
    To cure the size error, you need to go into option adjustment set up. Push and hols “Start”, then push “Power”. Power off, then try it.
    ricoda
    Hi Penguin, thanks for reply
    how do i get into option adjustment ?
    cheers Dave
    #163847
    Just do what the post above says, and that should reset it.
    ricoda
    thanks penguin, that sorted it out, it’s buisness as usual for the washing now 🙂
    missus said she owes you a big kiss 🙂
    cheers Dave
