Re: Fisher & Paykel Smartdrive 701 fix
Ian Solder another feed
wire this time to the centre pin and off course so far so good. Looks
very rough and absolutely cost a lot more in more time than simply
replacing a $41 component. However, a very nice feeling by way of
accomplishment.
Just in passing I now have a better understanding of the Hall effect and
the use of micro sensors.
(http://content.honeywell.com/sensing/pr … llbook.pdf)
I read that the motors are also desirable as wind turbines so had a bit
of a play manually spinning the motor and measuring the voltage generated.
