I have the above washing machine and the Start/Pause touchpad recently became worn and difficult to push and it often took a few attempts to get the machine to start. The diagnostic error code is 36. I assumed it was the display controller that was the issue but do not want to fork out $100 for a reconditioned one unless I can be sure that is the problem. Can anyone help with the error code? F&P do not provide this information in Australia.
regards Malcolm
36 – water leak – machine has to keep topping up. It may well be syphoning; the end of the drain hose must be above the highest possible water level in the machine.
That doesn’t seem to be the problem. There has been no leakage. maybe I misinterpreted the binary code. If you read lights on as 1, then it was 00100100. Or maybe I didn’t enter diagnostic mode properly. I pressed Wash Temp Down for a few seconds then Power. The lights came on as above. I read somewhere something about pressing the Spin Speed “buttons” for further info, but nothing happens when I do.
malcolm
