My machine is not filling even with cold water. It gets so far very slowly then starts to do the fast beeping. The hot and cold lamps are flashing. I have checked all filters and hoses. The diagnostic test did not light any lamps along the top. If I manually fill for the wash and then again for the rinse everything works fine. (If I can find out the problem the electrical engineer in the house may actually look at it !!!)
I did the diagnostics according to your sticky no lights lit up at the top.
from the service manual I did the test at 8.3 to test the pump and water valves. Pump worked. Cold worked. Hot no water. Is this the problem ?
We now have the part. How do we remove the bracket to fit this? They don’t seem to be screws holding it in are they something you need a special tool for ?
