Fisher & Paykel smartdrive washer Model gw709au
Home Forums Public Support Forums International Forums Australasian Appliance Forum Fisher & Paykel smartdrive washer Model gw709au
  • #10129
    slasher
    water pumps out but Spin cycle does not actuate, require information on possible fault.
    #138499
    alexa
    Post your email and I’ll send you the diagnostics
    #138500
    slasher
    Re: Fisher & Paykel smartdrive washer Model gw709au
    my email is ddb69@optusnet.com.au
    #138501
    alexa
    Attached please find the diagnostics
    #138502
    slasher
    Thanks for the diagnostics, it has solved the problem with the spin cycle, Much appreciated,
    Kind regards, Slasher. 😀
    #138503
    slasher
    It appears that the spin cycle problems has resurfaced. The machine did work properly for 4 washes only. The fault codes are outlined below.
    Level 3 0010 0101
    Level 4 0000 0001
    Also is it possible to have the diagnostic for the other fault code levels.
    PLEASE HELP!
    Slasher
    #138504
    alexa
    Slasher Wrote
    I’am sorry to bother you again, but it seems the fault relating to the spin
    cycle has occurred again. Is it ok if i contact you direct by email, instead
    of using the forum.
    #138505
    alexa
    The forum is there to also assist other people so your posting there is mandatory
    #138506
    alexa
    There are hundreds of fault codes and the manual is copyrighted so under fair use policy I can only copy individual pages not the whole manual.
    Level 3 fault code is the one of interest and it is a pump block error.
  • The topic ‘Fisher & Paykel smartdrive washer Model gw709au’ is closed to new replies.
