Fisher & Paykel “Smartdrive” washing machine motor control
Home Forums Public Support Forums International Forums Australasian Appliance Forum Fisher & Paykel “Smartdrive” washing machine motor control
  • #66124
    peterlonz
    Hello everyone,
    My very first post & it concerns a brand sold in New Zealand, Australia & the USA.
    I am unsure if the “Fisher & Paykel” brand is distributed in the UK.
    Anyway, they utilise an electronic motor power controller to control their patented “pancake” drive motor.
    One of the water cooled 3 terminal PWM switches has failed along with several adjacent components.
    I have ID’d all but one very small diode like component & would dearly love to repair since a replacement board is $170.
    The component is about 2.5 mm body length by about 1.5mm in diam & looks like a diode.
    Is it likely anyone here could help, I guess some knowledge of the “F & P” control design would be helpful.
    Peter O
    #363170
    Re: Fisher & Paykel "Smartdrive" washing machine motor contr
    Hi Peter, just spotted this post.
    I have moved you to the Australasian forum, due to our resident Fisher & Paykel expert being indisposed you will have a better chance of an answer in here.
    Please feel free to bump the topic at any time.
    #363171
    peterlonz
    Quick follow-up:
    I eventually obtained all 6 of the replacement components with only a slight doubt about the diode in this thread.
    De-soldered all suspect components, cleaned the carbon “blast damage” to the circuit board, & re-fitted the new components.
    When the control board was reassembled in the machine & mains power switched on ………………. Bloody nothing !!
    Well I guess I asked for it because I have no real way of knowing what caused the initial fault or of testing the repaired board.
    I really think Fisher & Paykel should rethink there absurdly restrictive policy of not providing a circuit diagram with reference voltage check points.
    This item new is now priced at Aus$339 – about HALF the current cost to replace the complete machine. That does not include the technicians labour charge if you need a repair tech.
    Moral of this story is probably: don’t attempt a control board repair unless you are really experienced in such matters.
