Fisher & Paykel Washer Diagnostics error – 10000011
Home Forums Public Support Forums International Forums Australasian Appliance Forum Fisher & Paykel Washer Diagnostics error – 10000011
  • #27907
    chrispy185
    I have a Smart Drive 703 and would very much appreciate if someone could help me with the diagnostics of the below
    10000011 or yes/no/no/no/no/no yes yes.
    Any help would be greatly appreciated.
    Cheers Chris
    #216052
    Re: Fisher & Paykel Washer Diagnostics error – 10000011
    Rotor Position Sensor error. Unit may be faulty, wet or suffering from chaffed/corroded wiring. It’s mounted on the motor stator.
    chrispy185
    Thanks so much for your quick reply. What do you know I unplugged the unit left it for 24hrs did the dionostics test then hit start and it worked fine.
    I will have a look at it anyway.
    Thanks again Hope you have a wonderful day.
    Chrispy
    #216054
    chrispy185
    Well what do you know I am back here again after 12 mths. :rolls:
    Ok I have the same problem. 😳
    I have had a close look at the Rotor Position sensor every thing looks good to me with no dampness or dodgy wireing.
    I am wondering if now I need to replace the sensor as I get the same error.
    I can’t reset the computer (Start and power) as my start button doesn’t work and have been starting the old girl by delay for some years.
    #216055
    kiwireeferman
    703 is ancient, time to replace this old work horse
