Fisher & Paykel washer filling with hot water
Home Forums Public Support Forums International Forums Australasian Appliance Forum Fisher & Paykel washer filling with hot water
  • #10288
    pookky
    Now I have 3 Control modules that work fine apart from when set to fill with cold water it starts off on cold then after filling to about 10{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} it decides to switch to hot water.
    I have been pulling my hair out with it I have even chnged th thermistor on the heat sink but it is still them same.
    Any help appreciated.
    Gary
    #139392
    alexa
    All F&P’s will add small amounts of hotwater when filling even though the cold only is selected and indicated.
    User setting been changed?
    Posted your model No.?
    Posted your email address in order to receive the diagnostics?
    #139393
    pookky
    Re: Fisher & Paykel washer filling with hot water
    There is definite problem, I know small amounts of cold water are added to cool the mosfets on the heatsink, this should not need to occur duing filling as there is water flowing then and no heat build up. If anything it would feed cold water to cool but it is filling with hot.
    The boards are gw 051, 501 and 701 machines.
    I have swapped with other controllers in the same machine and all works fine.
    With the water temp set to cold it will fill for a short time on cold then turns off cold soleniod and turns on the hot and continues to fill.
    If it was only 1 board I would not worry but I am getting 3 of them all with this fault.
    Not sure about user setting I have been working on these with no service info.
    My email address is gary_lek@aapt.net.au
    #139394
    alexa
    Have sent you the diagnostics
    Run the diagnostics then post back in the forum with you fault code
    #139395
    alexa
    Pooky wrote
    Thanks for the help will try it very soon.
  • The topic ‘Fisher & Paykel washer filling with hot water’ is closed to new replies.
