Home › Forums › Public Support Forums › International Forums › Australasian Appliance Forum › Fisher Paykel washer fills/drains same time
- This topic has 6 replies, 4 voices, and was last updated 20 years, 8 months ago by
admin.
August 12, 2005 at 9:32 pm #11290
KeymasterWhen wash water reaches first water level (low), washer begins draining as it fills. It also does it at the beginning if I manually select a level at the start. It has nothing to do with the drainage hose. I moved that around, but no change.
Any suggestions? Thanks!…Barbi
EcoSmart Model #GWL 10 US
Serial #CYN599901August 12, 2005 at 11:22 pm #144670Penguin45
ParticipantRe: Fisher Paykel washer fills/drains same time
If there is a fault, you should get flashing lights across the wash progress part of the control panel. If you could get a note of which ones are lit (it’s a binary code from right to left), we may be able to advise further. Initial thoughts are a problem with the water level control switch.
Penguin45.August 13, 2005 at 8:41 pm #144671KiwiwantsworkinCanada
Check the diverter valve. Remove the valve, as there might be a piece of something jamming it open. Located on bottom right side bottom of tub to the back and no special tools neeed to replace. Disconnect from the power, tip washer back on a 45′ angle, and the valve is right next to the drain pump. Three hose clamps, two wires and a phillips screw, watch how it comes out as it has to go back in the same way. Put a pan under to catch water that comes out when you disconnect the hoses from the valve.
I hope this helps:wink:
August 14, 2005 at 10:12 am #144672Bill
I do not know the model but my training with them was if there is a leak some where this could happen! give it a try.
Bill Ellis :lesson:
August 14, 2005 at 7:18 pm #144673KiwiwantsworkinCanada
It is a US model. It looks like a standard smartdrive, but F+P put a diverter valve in to improve the efficiency. 8)
August 15, 2005 at 3:11 pm #144674admin
KeymasterRe: Fisher Paykel washer fills/drains same time
I am so happy to tell you that I am washing some very dirty clothes right now! KiwiwantsworkinCanada, you were right…it was the diverter valve. I wasn’t able to get down on my old knees until last night to check it out. And this morning…went for the big wash…and hooray!
You are a lifesaver to two older, ill-healthed people who could never afford to have someone else fix this machine. We bought it three years ago with a little inheritance money. I can’t thank you all enough for your generosity in helping, or trying to help. You are doing good work!
Thanks again,
Barbi 😀August 15, 2005 at 6:48 pm #144675KiwiwantsworkinCanada
No Problem 😀 , and thanks for the feedback!
