Fisher Paykel Washer Mainboard Fault
Home Forums Public Support Forums International Forums Australasian Appliance Forum Fisher Paykel Washer Mainboard Fault
Viewing 8 posts - 46 through 53 (of 53 total)
  • #125068
    alexa
    Have resent
    #125069
    gjdante
    Hello, I suspect from what I’ve read that the motherboard on my Smartdrive 053 is not well.
    I’ve gotten into the diagnostic mode (I think, and ) and get a cycle of the following when I press the key
    1. 0000 0000 with High and Low level lights on
    2. 0100 0100 with Low level light on
    and repeat…..
    Is there any hope or should I look for another mainboard?
    gjdante@tpg.com.au
    #125070
    alexa
    Dont press the advance key
    Need level 3 fault code
    #125071
    gjdante
    Thanks for the diagnostics – we narrowed it down to the lid sensor in about 5 minutes.
    Temporarily shorted it out and away it went.
    Thanks again.
    #125072
    Re: Fisher Paykel Washer Mainboard Fault
    fykl wrote:Hi – I seem to be having a related problem.
    My Fisher & Paykel Smartdrive 085 turns on OK, all buttons seem to work to change settings, but when I press start/pause, nothing happens. Can’t wash, can’t rinse, can’t spin. The board has been replaced once before and since that’s such an expensive exercise, we’ll just buy a new machine if it needs replacing again.
    I’ve looked inside and the tech sheet is not in there. Fisher & Paykel in Australia refused to send a tech sheet too. (Although I have read that in NZ they will send a service manual to consumers?)
    I’ve run the diagnostic mode and get the following:
    00000000
    00000000
    00000000
    01000100
    00110111
    00000010
    00000011
    00011001
    01000001
    00000010
    11111111
    000000**
    00100100
    01001001
    00010100
    The ** above indicates where the last 2 LEDs alternate between 0 and 1 (when one becomes 0, the other becomes 1).
    If anyone can either help me get hold of a tech sheet/service manual, or help me to interpret these codes, I would really appreciate it. I can be reached by email to ennio at bigpond dot net dot au.
    I have the same problem, what was the diagnosis?
    #125073
    alexa
    Level 3 is the current fault code indicating your is 00100100
    This indicates your machine may be:
    1/. siphoining
    2/. leaking
    or
    3/.power module needs replacing.
    Raise the outlet end of the drain hose to prevent siphoning.
    Check for water on the floor to confirm leaking
    If these don’t solve the problem then a new power module may be required
    #125074
    G’Day to ALEXA
    thank you very much for the diagnostics info.(very promt, you must also sit on that puter all day).
    anyhow when i went to test ,the damn machine went o.k. for next 4 washes, but now back to same trouble.
    ie.stops at led prior to short wash and beeps
    the macine is smart drive MW051 Phase 2
    the error code i get is 130 (i think)
    any sugestions from here please
    #125075
    alexa
    Kudos4
    Email has fault code 130 attached
  • The topic ‘Fisher Paykel Washer Mainboard Fault’ is closed to new replies.
