fisher & paykel what is the LSB for eror codes?
Home Forums Public Support Forums International Forums Australasian Appliance Forum fisher & paykel what is the LSB for eror codes?
  • #38908
    grimreaper
    I can cycle through about 15 error codes using the spin up button, what is the least significant bit when reading error codes, eg the long wash or spin? Also why do I get so many different codes when cycling thru the menu. 15 in total. I’m thinking the RPS sensor is at fault as everything else tests ok thru the diag tests, but I cant get it to spin
    #260323
    Re: fisher & paykel what is the LSB for eror codes?
    The fault which has stopped the machine is the first one you have re-called. The others are in descending order of occurence – the machine may have managed to work through them.
    Care to share the first one?
    grimreaper
    It ended up being the RPS sensor which I found had a burnt track. Not good I know but everything tested ok so I resolded a link in and away the machine went. Saved myself some money hopefully. Did 3 washes today. The sympton was cold water solenoid turning on(0.5 sec) and off(2.5sec) repetatively for 30 seconds before returning an error code of 131.
