Fisher Paykell does not work (Diagnose code 136)
Home Forums Public Support Forums International Forums Australasian Appliance Forum Fisher Paykell does not work (Diagnose code 136)
  • #31410
    ianlouisshaw
    Hi Guys,
    I have checked the diagnostic on tmy broken Washer Machine and realised a code of: 136.
    Can you help me please??
    Washer machine details:
    Model No: GW609AU
    Serial No: AUL630836
    Initiall when power turned on all of the lights come on and when I press continue the washer machine accepts water for a while and then turns off and then accepts and turns off etc.
    Please help me I have two young kids!!
    Cheers,
    #231102
    ianlouisshaw
    Re: Fisher Paykell does not work (Diagnose code 136)
    The code was from left to right:
    ON-OFF-OFF-OFF-ON-OFF-OFF-OFF
    i HOPE THIS HELPS!!
    #231103
    Computer can’t run the motor.
    Wiring problems most likely, rotor Position sensor can cause this, stator problems, drum bearings/drum jammed or seized or possibly even the computer board itself.
    ianlouisshaw
    Penquin is their any way that I can eliminate this any further!!
    I have checked the water pump via multimeter and it appears fine (30 ohms across the terminals).
    I am able to accept the hot or cold water corretly (un-interrupted when in diagnose mode so I think both of the water solinoids are OK!!
    The stator is able to be turned quite freely when power is removed so I think it apears OK whilst the power is off
    How do I check the stator position sensor?? I do not know how to do this??
    Many thansk for your help
    PS> the washer is 12 years old, do you think I should just get a new one rather than persisting??
    #231105
    If you have a multimeter, you’re half way there. Continuity from PCB to the motor is the place to start, continuity through the stator windings etc. These machines suffer from corrosion and chafing of the wiring around the turn of the bottom of the drum and as it tucks under the rotor.
    That said, 12 years is a good age for a washer………
    ianlouisshaw
    As it happens Penquin I do have a multimeter!!
    I am unsure where abouts the motor wires are located. How do I locate these babies?
    How do I check the continuty of the stator windings??
    Sorry in advance for being a dummy washer machine mechanic!!
    Thanks Penquin for your continued help
    Cheers,
    Ian
