Hi have done the diagnostics and the fourth light from the right is lit up, and I hope I am reading the error code correctly.
Machine stopped mid-cycle, beeping continuously.When attempted to restart it would only fill or empty in short bursts rather than continuously and I cannot get it to spin.
Can you possibly tell me what the error code means?
Typical things to look for Out balance microswitch corroded terminals Etc
Rotor sensor /Numerous threads on this Problem
Washer Must pump All the Water before it goes on to Spin
Check pump for blockages Or Over heating
