Fitted Neff k4664 larder fridge with freezer inside
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Fitted Neff k4664 larder fridge with freezer inside
  • #78955
    golgol
    Having replaced the relay & capacitor on this fitted fridge it started to work fine. Once we put it in its housing it started running very noisily & freezer near the top reached -30c & top shelf -1c but bottom shelf wouldnt get cold. Is there any hope for it? Have we caused a leak in putting it in its cupboard? Is the compressor coincidently on its way out? The windings on the compressor are fine. If we invest in regassing it can they detect & fix lany leaks first? The evaporator is concealed.Its 8 years old. Thankyou
    #407466
    golgol
    Re: Fitted Neff k4664 larder fridge with freezer inside
    Noise problem was just a loose freezer shelf. Temp ok now. Only problem seems to be that it tries to draw 5.4 amps a few times to start. Stops immediately & then starts normally with 0.64 amps going down to 0.5 amps. Can this be dangerous or can we live with it? Thank you.
