Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Fitting a drive Belt to Hotpoint washing machine
- This topic has 7 replies, 5 voices, and was last updated 20 years, 8 months ago by
admin.
July 21, 2005 at 1:10 pm #10821
KeymasterShort story belt broke, ordered new belt, Bag belt is in lists my machine as using the said belt. Checked length, grooves etc against new belt, all is good.
But….. 😥
Took the top of machine, dropped belt down over pully wheel at back of drum, to find that the belt is about 1 inch (2.5cm) away from the drive of the motor. No amount of pulling etc will allow me to get that belt over the motor.
Thought I would undo the bolts holding the motor in place and maybe that would give me enough purchase to get the belt on? Nope still cant even get the belt to touch the drive spindle.
At this point I figured that there must be a well known ‘trick’ to getting these belts on. So tried the old bike chain method of putting the bet around the motor drive and feeding it onto drum and rotating drum to hopefully pull the belt on, but alas all it did was slip and wouldnt go on.
Desperately seeking help here!!
Regards
Mr No Hair.
July 21, 2005 at 1:18 pm #142854Washman
ParticipantRe: Fitting a drive Belt to Hotpoint washing machine
HI
Whats the Model number of machine And the part number of the belt you have So that we can check
Mike
July 21, 2005 at 1:25 pm #142855admin
KeymasterRe: Fitting a drive Belt to Hotpoint washing machine
At work just now, will get both sets of information added to post when I get home. Was hoping it was a common problem and i was just doing something wrong 🙁
Regards
Mr No Hair
July 21, 2005 at 1:40 pm #142856Martin
Thread the belt around the motor pulley and lash the other end to the main drum pulley using a plastic bag tie to hold it in place and to prevent it slipping off as you turn the drum by hand.
Once the belt rotates over the main pulley, simply cut the bag tie off and away you go 😀
Hotpoint engineers use a special tool (large tubular bar) that stretches the belt over the motor pulley. 😉
July 21, 2005 at 1:56 pm #142857admin
Sounds like a plan, thanx very much I will try and implement over the weekend and post my results.
Much appreciate the help here
Regards
Mr Hope of Hair growth
Bill
July 21, 2005 at 2:02 pm #142858Martin
EnofTether ReInspired wrote:Mr Hope of Hair growth
Live with it dont fight it :rotfl:
July 24, 2005 at 7:14 am #142859Phidom
Yes, Hotpoint have gradually gone from having the easiest belt fitting access/design on the 95 series made in the ’80s to one of the most difficult, on the WMA machines.
July 24, 2005 at 3:19 pm #142860iadom
ModeratorRe: Fitting a drive Belt to Hotpoint washing machine
Phidom wrote:Yes, Hotpoint have gradually gone from having the easiest belt fitting access/design on the 95 series made in the ’80s to one of the most difficult, on the WMA machines.
Takes all of two minutes with the plastic bag tie technique. 🙂
