Fitting a new door on a Generation 2000+ G2P 90F/SS oven
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Fitting a new door on a Generation 2000+ G2P 90F/SS oven
  • #78816
    garnem
    The outer oven door on my Generation 2000+ G2P 90F/SS oven has smashed as the hinge broke. The top handle has also come off. It appears that the glass is glued onto the metal. Is it possible to replace the outer door or do I need to get a whole new oven? Where would I get a new door? Plus can the oven be used in the meantime as the inner glass door is intact and the oven can be closed.
    #407015
    Re: Fitting a new door on a Generation 2000+ G2P 90F/SS oven
    The door will be glued using Ambersil, a heat resistant glue which is here:
    http://shop.ukwhitegoods.co.uk/ambersil … stant-glue
    To find the door glass I’d need the PNC number from the rating plate.
    And, no, the oven cannot be used without the outer door glass as it would be pretty dangerous to do so.
