Fitting new door to beko dishwasher
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Fitting new door to beko dishwasher
  • #101538
    Bob Blake
    I need to fit a new door to a used BEKO DIN28Q20 dishwasher. I have all the bits except I have no template to guide where exactly i need to place the door and make the screw holes. All the Youtube guides assume the machine is new and the paper templates are available. I have also searched for templates without success. Any ideas how I can get the replacement door to fit perfectly?
    #485157
    you can do it by just measurement
    you have the plastic frame. it has to be central left to right all you need is the vertical
    clip frame into door, then measure from the screw holes to the top of the control panel
    then make same measurement on the door panel. put 2 screws each side and try to see if it fits
    if ok fit all screws
    Bob Blake
    Thanks for the tip Dave. I will give it a try.
