fitting of thermostat beko fridge/freezer
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum fitting of thermostat beko fridge/freezer
  • #7674
    cowboy54
    HI,
    trying to fit a new thermostat to a Beko fridge freezer. The thermostat has numbers on it 3, 4, 6 relating to a terminal.
    Anyone know which colour wire goes to which, wires are coloured black, brown and purple
    Gareth
    #124615
    Dave_Conway
    Re: fitting of thermostat beko fridge/freezer
    Sorry, we can’t help with this as the lead colours in aplliances are not in any way related to what they actaully connect to I’m afraid.
    All I can give you is:
    6-4 is the temperatre control switch
    6-3 is the auxillary switch (light/heaters etc)
    #124616
    You should be able to work out which is which by tracing the origin of the cables at the compressor terminal block and doing continuity tests on each cable in turn.
    Although most of us on this site know the answer, we can’t tell you in case you do it wrong. In law you could hold us responsible, and as you state there are three colours you have already made an error by omitting/dismissing the earth cable, the most important of the 4 wires present.
    Kevin
