Fitting thermistor to Indesit WIDL126
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Fitting thermistor to Indesit WIDL126
  • #38411
    markrw
    After advice from this forum I am trying to replace the thermistor in my washer/dryer.
    I rec’d the part today and although it has the same part number as the old one (279) it looks different.
    The old one is connected to by a plug whereas the new part has 2 rectangular prongs each with a hole in it.
    Can I use this new part, maybe by cutting off the plug and soldering, or do I need a different part.
    I’ve attached some pictures for info
    thanks for your help
    Mark
    http://i330.photobucket.com/albums/l433 … chine1.jpg
    http://i330.photobucket.com/albums/l433 … chine2.jpg
    http://i330.photobucket.com/albums/l433 … chine3.jpg
    #258789
    markrw
    Re: Fitting thermistor to Indesit WIDL126
    PS. The new thermistor prongs fit onto a red spade crimp. Could I remove the plug from the wires and crimp??
    Cheers
    Mark
    #258790
    helo_75
    as much as im tempted to say it would be ok, if you soldered the wires on, id prefer to say that you’d be better off with the correct thermistor
    u need an idc type
    your call…
    #258791
    helo_75
    if im right, then the one you want is a dryer thermistor…
    the one you have is a wash thermistor
    correct part number is c0098739 for the dryer thermister
    could you clarify which one it is please?
    #258792
    johnnyj
    Think the one you have is the the pre idc connector dryer thermistor, the wash thermistor is a plastic can this has a metal can.
    #258793
    markrw
    Helo_75. The part number for the new thermistor is C00080767. Please refer to my previous post
    http://www.ukwhitegoods.co.uk/modules.p … ht=#192293.
    Cant find the new part number on the uk whitegoods parts section
    Cheers
    Mark
    #258794
    helo_75
    http://shop.ukwhitegoods.co.uk/contact_ … ae71043408
    if you fill the form in, they will send you one quick sharp, im sure
    i remember you now, u will need this part c0098739
    to be sure it runs at the right temp!
    sorry for any confusion
