Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Fitting thermostat in Zanussi ZX57/3
- This topic has 10 replies, 3 voices, and was last updated 19 years, 3 months ago by
ODB.
January 5, 2007 at 3:14 pm #23874
ODB
ParticipantHi there
After a bit of detective work it looks like it’s the thermostat that’s gone in my fridge.
Now’s the tricky bit – can anyone tell me if it’s within the capability of myself to install? I haven’t had a close enough look to even know where it goes yet!
Thanks!
January 6, 2007 at 3:37 pm #199680ODB
ParticipantRe: Fitting thermostat in Zanussi ZX57/3
OK without any instructions or guidance whatsoever I tried to do this myself.
First, I turned off the fridge. I had no idea where the thermostat went, so after a little hunting down I popped the top off and found out it was (of course) connected to the thermostat controller (the temp dial thing) on the outside of the fridge.
The top was easy enough to get off and after a bit of umming and ahhing I got the thermostat out and unplugged. All that was needed was a phillips head screwdriver and some pliers to undo the nut that secures the thermostat dial.
Only thing is the thermostat that was already fitted had a sensor (long wire) that led off and disappeared into a hole into the depths of the fridge. So I yanked it but only managed to get it out about 4cm. It was stuck. It obviously wasn’t going anywhere so I thought as it’s just a sensor maybe I can get away with cutting it off and just twisting it up with the the other sensor. So that’s what I did.
I turned it on and wa-hey! The fridge made all the right noises. So I packed it all back and just before putting the top back on I tested it one more time. Again, the fridge kicked in. Brilliant.
So I put it all back together, plugged it in and…nothing.
Somehow, inbetween me testing it and putting the lid back on the top, it broke. Again.
Bugger.
January 27, 2007 at 6:09 pm #199681admin
KeymasterRe: Fitting thermostat in Zanussi ZX57/3
have you sorted the problem or do you still need help
tony ❓January 31, 2007 at 1:32 pm #199682ODB
The fridge i sitting in my hall, still knackered. Just wondering if what I did with the thermostat sensor wire is acceptable and ok to use?
I am considering changing the thermostat again and giving the fridge to a mate who has just got a new house. Any suggestions? Shouls I kep plugging away at it?
January 31, 2007 at 5:42 pm #199683admin
the piece you cut is a cappilary tube with gas in it thats why its probably not working mate
the other end is usualy conected to the plate inside the fridge you will need to loosen that end b4 you can release it
let me know how u get on
tonyJanuary 31, 2007 at 5:53 pm #199684ODB
That explains a lot. Any idea where the end of this mystery bit of wire might be located in the fridge? Down the back near the compressor??
January 31, 2007 at 6:07 pm #199685admin
usaly fixed to the plate inside the fridge
January 31, 2007 at 6:16 pm #199686ODB
Plate? You mean the on with all the serial number on it and stuff? Or near the light? Sorry for being a muppet – if it was a car or pc I’d know with my eyes closed but fridges are a mystery to me.
January 31, 2007 at 6:19 pm #199687admin
is there a cooling plate on the back wall of your fridge or is it just plastic
January 31, 2007 at 6:20 pm #199688farmboy
The other end of that “wire” sits in a small tube in the pastic air duct housing at the back of the fridge, you will have to remove the housing to do it.
January 31, 2007 at 9:53 pm #199689ODB
OK thanks. I will take another look – if I can find it I’ll buy nother thermostat!
