Re: Fixed pump, but now machine overfilling
Hi there – I put the machine on its side, took out the pump and it was full of gunk, so cleaned it, popped it back in and all good. Other people’s wisdom and experience via You Tube helped lots. Good luck!
Have since discovered the current overfilling problem isn’t do to with the actual pressure switch but the hose that connects the switch to the pressure chamber – took it out to find it has a huge hole in it, so no wonder there was a problem! Brilliant, and am off to buy some hose right now…
