The engineer has had a quick look at our leaking dishwasher and confirmed what I thought, i.e. the leak is coming from somewhere up the right hand side (up where the fresh water inlet to the main wash area is).
From looking at the exploded view of a dishwasher under the help and advice section is this likely to be a leak within some kind of matrix and if so, how easy will this be to fix? I was advised that it would be over £100 to fix and considering its nearly half the cost of a new one, thought i’d have a go myself.
Just want to know what i’m letting myself in for.
Also, I guess the easiest way is to lay it on it’s side and remove the bottom panel?
cheers
