Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › FJ1296 No Spin
- This topic has 9 replies, 5 voices, and was last updated 17 years, 7 months ago by
hotpnt.
September 1, 2008 at 4:45 pm #39136
hotpnt
ParticipantHi, hoping this will be a simple one for someone to answer,
Zanussi FJ1296 complaint no drum action, motor seems ok, brushes perfect & continuity through pins, wiring all fine from motor to module & timer,
Took module out & had a look, could not see anytthing blown,
Put back in & tested from motor, 240v across all pins at some point to earth, then on spin prog after about 2 minutes the motor turned twice for about 3 seconds with a 10 second gap, then no more, put on a rinse & machine filled tumbled again clockwise for about 10 seconds then paused, then 10 seconds again (still clockwise)
So module or timer fault?
thanksSeptember 1, 2008 at 9:54 pm #261415hotpnt
ParticipantRe: FJ1296 No Spin
anyone please>?
September 1, 2008 at 10:36 pm #261416leavemetogetonwithit
Got two or three modules that look like that, one new, others s/h. Could lend them to you to try in. PM if that’s any use.
Mike.September 1, 2008 at 10:57 pm #261417aqualectric
546546 or 546547 computer board fitted to this machine – both suffer with motor control issues. Look at http://www.emwelec.co.uk, best way to repair the machine cheaply. And if your diagnosis is wrong, send it back!!
HTH,
Steve.
September 2, 2008 at 2:57 pm #261418hotpnt
hi aqua, the pic of those modules on EMW look different shape, its more like the square one 4004 etc, not sure which it is thoug!
September 2, 2008 at 3:35 pm #261419laurenceuk
Just ring EMW up with the model number and the number off the timer.
They often supply timers and boards together at a good price.
Just have a chat, they are very helpful and as has been alluded to – if it`s not the problem just send it back for a fiver.
Laurence
September 2, 2008 at 4:56 pm #261420admin
KeymasterRe: FJ1296 No Spin
hotpnt,
At first look I think that is PCB fault… from your description it makes movement on one side and after he make pause when he should turn in other side…
Verify which relay is activated when he is turning and in the other relay should be activated in other side movement (in your case=pause). If you measure 12V/24V on that relay but he isn’t moving, change relay…
Give please PNC… perhaps I can help with some info.
September 2, 2008 at 7:49 pm #261421hotpnt
type P6297236, Prod- 914787502-03
September 2, 2008 at 8:49 pm #261422aqualectric
Sorry Hotpnt, 😳 the FJ1296 is actually fitted with the 2004 timer and 4029 (blue spot) module. Both at EMW.
Steve.
September 3, 2008 at 6:25 am #261423admin
I’m sure now, after reading connection diagram and type of timer/PCB, that is timer fault. I have repaired a lot of this kind of timers… is usual…
I can send some info… email address?
