Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Flame on oven wont go higher
- This topic has 6 replies, 4 voices, and was last updated 8 years, 3 months ago by
christoffe93.
December 18, 2017 at 5:07 pm #92875
christoffe93
ParticipantI’ve notice the last few days that food is taking longer to cook so this time i used the cooker i waited a while after lighting to see whats going on, when i set the gas the flame wont go any higher than when it was fire lit regardless of how high i set the gas. If anyone knows what wrong your help would be much appropriate as everyone in the house is still using the cooker to cook without even known whats wrong with it.
December 18, 2017 at 6:07 pm #452439electrofix
ModeratorRe: Flame on oven wont go higher
most gas ovens have a flame failure device. what happens when you light it is a small amount of gas comes through and ignites. After it has been lit for about 30 secs or so the flame failure device detects it is burning and increases the gas flow. if the flame gets blown out the same device will lower the gas flow to try and stop explosions
if this has failed the amount of gas would be that low I cant see how anybody could use it
December 18, 2017 at 6:53 pm #452440christoffe93
ParticipantRe: Flame on oven wont go higher
Thanks for your reply dave do you have any idea how much it would cost on average to fix? And is it still safe to use it like that or should i tell everyone to stop using it.
December 18, 2017 at 7:23 pm #452441electrofix
if we knew make and model we could get a part price
as for labour depends on local labour rates you could find a local engineer and ask
December 18, 2017 at 7:30 pm #452442kaibart
This could well be a ffd if it’s a rangemaster and this is something that has to be repaired by a gas safe engineer
December 19, 2017 at 4:39 pm #452443christoffe93
If its of any help the make and model is hotpoint GW74P. The cooker can also run on LPG so i dont know if this will make it harder to find the correct part.
December 19, 2017 at 4:45 pm #452444kwatt
KeymasterRe: Flame on oven wont go higher
It should be this one:
https://shop.ukwhitegoods.co.uk/gas-ove … ure-device
The gas supply does need to be broken so it is highly recommended that you have that done by a Gas Safe registered repairer.
