Flashing LEDs on F&P Smart Drive 501
Home Forums Public Support Forums International Forums Australasian Appliance Forum Flashing LEDs on F&P Smart Drive 501
  • #11308
    Hi, my smart drive 501 is working fine but the 5 washing LEDs keep flashing all the time. anyone knows what is going on? i am thinking to upgrade to a larger machine but can’t sell this one because people think there is something wrong here. PLEASE HELP.
    #144773
    Re: Flashing LEDs on F&P Smart Drive 501
    Turn machine OFF on the front panel. Hold down the Water Temp Down button and press the POWER button. Release buttons. You are in Diagnostic mode. Press advance once, press the spin speed up button until the hold and slow are lit. Write down the LEDS which are lit across the top row of progress LEDS. and post back. 😉
    #144774
    none of LEDs lit under diag mode, but after pressing POWER to exit diag mode, they are flashing again. thanks KIWI.
    #144775
    The WM is in ‘auto restart off’ mode, probably due to corrosion on the display board. I am assuming that you have tried turning it off at the wall, and leaving it for a minute.
    Not a big problem, but shows that one or both of the board circuits has corrosion, and will lead to more problems. 🙁
    #144776
    FastAndPro
    Go into the diagnostic mode and togle the low water level light on by pressing the water level down light do not togle the high water level light or the machine will wash forever
