Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › flashing light on wate dispenser
- This topic has 9 replies, 5 voices, and was last updated 20 years, 4 months ago by
MGA.
December 6, 2005 at 5:23 pm #13864
MGA
ParticipantHi.
I have a flashing light on a whirlpool side by side F/F water dispenser, does anybody know what this means as I have been told it should not be flashing.
The ice is being made ok.
the model is 8586 151 15010
many thanksDecember 6, 2005 at 5:48 pm #156979admin
KeymasterRe: flashing light on wate dispenser
hi
it may well be that it is the water filter renewal light,have you got your handbook ?
bryan
December 6, 2005 at 7:47 pm #156980MGA
ParticipantHi Byan,
no, I do not have any kind of documentation for thisDecember 6, 2005 at 9:42 pm #156981DentedPorsche
ParticipantRe: flashing light on wate dispenser
The filter light should be a steady light. It’s a tricolour led and shows green if it’s ok, amber when it’s nearing the end of it’s life and red when it should be changed.
As to the flashing light, it wouldn’t be a green light with a key symbol to the left or right of it would it?
If you could describe where the light is on the control panel it may help pinpoint the problem.DP
December 6, 2005 at 10:59 pm #156982gegsy
This model will display error code in 7 segment display/s, not any flashing lights to indicate fault.
December 7, 2005 at 7:15 am #156983DentedPorsche
If there’s a problem with one of the door switches giving a door open situation it will be indicated as a green flashing light on the front panel, it should also be accompanied by an alarm sounding.
If it’s the numbers that are flashing then the temperature in the affected cabinet has risen above “safe” temperature.DP
December 7, 2005 at 10:49 am #156984MGA
ParticipantThe flickering panel affects all the lights on show including the digital temperature readouts. The flickering varies between roughly a quarter to a half a second and is accompanied by a ticking noise.
December 7, 2005 at 6:50 pm #156985gegsy
ParticipantMGA wrote:The flickering panel affects all the lights on show including the digital temperature readouts. The flickering varies between roughly a quarter to a half a second and is accompanied by a ticking noise.
In that case you will need to change the rear pcb module and possibly the front display pcb.
December 7, 2005 at 6:55 pm #156986MGA
Participantthis is what I thought many thanks for your help all of you
December 11, 2005 at 8:32 pm #156987lokring
its usualy just the user contrpl panel but i have had both 😀
