Hi, I have an Indesit WIDX L146.
Just looked at the fault codes for this machine and the code given is apparantly not used. I have (from left to right) 2+3 flashing (easy iron and extra rinse flashing) together with the lock button flasing. The drain pump is running continuosly when the fault appears and the machine can only be switched off at the socket.
Any suggestions?
Many thanks
