Flavel Aspen 100 cooker
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Flavel Aspen 100 cooker
  • #95169
    Boz
    hi.
    fan oven has no power. Grill has no power.
    Clock working ok.
    other oven working ok.
    can anyone assist?
    Is it the thermal cut out?
    Model is AP10FRS.
    thanks
    #459601
    Boz
    Thank you. Appreciated
    #459603
    Boz
    Hi again. Fitted thermal cut out and grill and fan oven now have power. However, grill is working 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} heat but fan oven at about 50{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} heat. Won’t get fully hot. Is element or thermostat faulty? Would element or thermostat have blown which caused thermal cut out to blow too? Thanks.
    #459604
    Boz
    *power, not lower
    #459605
    most ovens have a light on the front of the cooker that turns off when the oven get to temperature. if the thermostat has a problem this light will go off early before it reaches temp. check the sensor in the oven, make sure its clipped in the correct place as if it too near the element it can cause problems
    elements normally work or they don’t but there is always the rare exceptions
