Flavel Dishwasher – Lights come on and then just goes dead
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Flavel Dishwasher – Lights come on and then just goes dead
  • #101295
    rayjdav
    Hello all,
    I have a Flavel FDW64 dishwasher.
    Worked perfect until 2 days ago. Now, when I go to set the cycle, control panel is not activating.
    I have disconnected it to see if it is a socket issue but when I switch the socket on, the machine beeps, lights flash, so there is power getting to it.
    But then when I try to set a cycle, nothing. I press the left on/off button, nothing.
    Is there anything I can try to see if it will work or is it a case of replace. Cost of d/washer v spares, not really worth it.
    I did not notice any strange noises previously to let me know of failing pump etc…
    And help appreciated.
    #484220
    well these faults can be a problem
    check the wiring from the door control to the board. remove any plugs and replace
    if it works then ok if not it can be
    either board or the cable joining the two
