Hello,
DW underfilling, hit start and fills some more, then stops, repeat a number of times and the DW overflows. No wash pump action ever though “free”, drain pump working.Has anyone come across this before? All valves and pipes OK. Is this an electronic fault.
Thanks,
Conor!
Beko have a machine under the same model number – if this is the same as the beko it lokks like it has a flow meter attached to the inlet water unit/airbreak on the LH side of the machine
