Flavel DWF 640 Dead
  • #73221
    King2
    I have a flavel DWF 640 Dishwasher that stopped working during a wash cycle.It does not now seem to be getting any power even though the Plug fuse and socket are ok.Is there a fuse in the machine itself that could have blown? Thanks
    #386808
    Seamy
    Re: Flavel DWF 640 Dead
    Check the on/off switch first, then p.c.b, power off when testing.
    #386809
    King2
    Ok thanks, Is there no fuse inside the machine that could have blown? The reason I am asking is that I think there may have been an ongoing problem with the dishwasher draining, at times there would still be water in the machine at the end of a wash cycle.
    I saw on another forum in a discussion about a different make and model that if the machine cant drain the pump will run for too long and cause a thermal fuse to blow. I thought something similar may have happened here.
    #386810
    Seamy
    No internal fuse, supply goes to on/off switch then to terminals 1(L) & 2(N) of KN2 edge connector on P.C.B, door switch comes into place to operate appliance, e/g it wouldn’t run unless door is closed.
    #386811
    King2
    The on/off switch was faulty, thanks again
    #386812
    King2
    This beko switch looks like the one in the flavel machine.can you confirm it is the same?
    http://shop.ukwhitegoods.co.uk/18331204 … off-switch
    Is there a better alternative as this switch seems to be a poor design and likely to fail again, thanks
    #386813
    Seamy
    1883250100 is the listed part.. here :-
    http://shop.ukwhitegoods.co.uk/18832501 … her-switch
