flavel fn10frk thermal cut out
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries flavel fn10frk thermal cut out
  • #73185
    JENKS
    merry christmas all,i have a callout tomorrow to above range,fault nothing working on one side.i have heard that its common on these for the thermal cut out to be at fault.is this a direct replacement or does the wiring need to altered,any help appreciated.
    #386671
    Seamy
    Re: flavel fn10frk thermal cut out
    It may be a terminal block fault either if nothing is working on one side, loose links perhaps. Thermal cut-outs in some of these were thermal fuse types, but most now are the t.o.cs, newer ones are auto-resetting.
    There is a kit 4410101001 that comes with wiring etc which is recommended to be replaced.
    #386672
    JENKS
    i have the kit that includes the wiring,do you know where the new thermal cut out fixes to.i see it comes with bracket.
    #386673
    johnnyj
    Take the back panel off nad it is sittuated half way down the bracketed on the side panel cheers JJ
