Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Flavel Milano 100 (ml10frsp)
- This topic has 9 replies, 5 voices, and was last updated 12 years, 7 months ago by
greenman1969.
August 26, 2013 at 11:37 pm #76854
greenman1969
Participanthi
problems with the main fan oven not working. thought it may have been the thermal cut out fuse but when i removed the back panel there is a brown and white wire which looks like has snapped. it has a rubber sleeve over it (the snapped section) which a silver component inside. i am not sure what this is and would i be able to get a replacement anywhere.
regards
seanAugust 27, 2013 at 1:40 am #400017Martin
ParticipantRe: Flavel Milano 100 (ml10frsp)
It’s a thermal fuse from your description.
August 27, 2013 at 4:16 pm #400018greenman1969
thanks for your reply,i was going to upload a photo of it just to confirm it but its saying file to big. apparently this part is discontinued and i am having problems locating the correct part as i need the the wire aswell as this is snapped.
can anyone point me in the right direction.
cheers
seanAugust 27, 2013 at 8:57 pm #400019greenman1969
would the replacement fuse kit include the cables/wires and is the fuse a disc shape..very vague i know but i am a bit sick of microwave meals now
cheersAugust 27, 2013 at 9:01 pm #400020captaincaveman1
Yes its now supplied as a thermal cut out stat and not a thermal fuse so the kit you describe would be correct.
August 27, 2013 at 9:29 pm #400021greenman1969
cheers captain
regardsAugust 29, 2013 at 3:10 pm #400022greenman1969
HI ALL
back again…just received new cut out fuse/stat for my cooker but being a nitwit i am not sure which spade connector goes on which one. i got the kit (new cables)and chased the old connection back to the fan oven but the other end has 2 connectors and i have another single cable… is there and diagrams etc cos i am stumped..i dont want to knack it all together
cheersAugust 29, 2013 at 3:39 pm #400023greenman1969
or is the two plug cable for one of the other models(beko etc)
anybody got any idea please
cheers
sean 😕August 29, 2013 at 6:27 pm #400024Seamy
No diagrams i’m afraid, if you are not up to doing the job, best advice would be to get an engineer to complete the job.
February 28, 2015 at 12:49 pm #400025masonj
I had problems with my fan oven being inoperative. Everything tested out fine but noticed that the pilot light for the oven was not lighting up, also that the control dial could be turned in either direction. Removing the top of the hob revealed that the oven control is in two parts. These had become separated. Once the back control was reseated, the pilot light returned and hey presto the fan oven now works. Worth a look.
