FLE1115w no spin
  • #49329
    cornwell40
    Intermittently 😥
    Thats the customers complaint. She washes on a synthetic wash, takes a few things out and then spins the remainder on top spin 😕 .
    The machine won’t ramp up into spin after this and then shuts down.
    She leaves the machine for twenty minutes and it will then spin.
    Only thing is I haven’t seen it :rolls: . Tested on spin, wash etc, meggered the motor all test ok. Drains fine with no unusual noises
    and filter is clean as a whistle. She insists it can’t be an OOB fault as its only cotton shirts etc that are left.
    Erm 😕
    Ideas on a postcard to…
    TC
    #299565
    Re: FLE1115w no spin
    the time would only be a factor if the pressure switch was blocked
    still sounds like an oob problem they may be light but if they are in a lump they may tip the oob cut out
    just a thought
    after 20mins water drips out clothes are lighter and may then spin
    TheSpinDoctor
    As far as the user is concerned:
    Unbalanced load=No spin.
    Seemples!
