flippin indesit again !
  • #20782
    sparepart
    I have an indesit in the workshop AWD12S , the obviuos fault is timer going round but the light flashes 13 times ? I suspect the board but am I right ? just dont have a spare around thats and didnt want to dothe wrong thing ……..as usual Thanks
    Sparepart !
    #188357
    AMS
    Re: flippin indesit again !
    Hi Sparepart,
    you’re in the very fortunate position in having EMW right on your doorstep. So why don’t you whip the board out and take a trip out to Oxton and have it tested/ repaired as necessary?
    sparepart
    yup, I suppose so ! just thought anyone had an instant idea ? but thanks !
    #188359
    AMS
    Saying that, I’ve just found some more info which says that F13 is “dryer fan does not work or ntc faulty”
    Hope this helps,
    Check for obvious loose wiring or broken connections on the top of the dryer heater box, in particular the very thin wires going to the NTC.
    #188361
    sparepart
    my thanks to Iadom and AMS , I’ve had this machine sitting here for ages bothering me ! ………this morning I checked the thought you had and on one of the spade connectors on the NTC the wire had cracked but the insulation was still gripped ! new spade connector and……..Hey presto ! my thanks to both of you for your help !
    Sparepart !
