My Candy C44000(3204250 513 4273) floods. The inlet water continues to run after the water has reached the appropriate level then floods out of the door. When I turn the control wheel round by hand it stops filling (presumably when the electric switch cuts the supply) and pumps out. I have fitted a new inlet water control valve but it has not made any difference at all. What can I try now please?
Power off, lean the machine back to a good angle and look for a black cover plate held on with three screws. Remove cover plate and remove all the goo revealed, especially inside the chamber.
Thanks a lot for that help, job done 30 minutes max. Perhaps it should be a regular maintenance job with a little easier access and a warning in the instructions. The consequences if I had not noticed the flood straight away and the machine was on the first floor, could have been dire. Thanks again.
Thanks Penguin, I have also had the same problem and have taken the bottom plate of to find it full of gunge. Unfortunately I did not pay attention to which way the plate came off. It will go back three ways, only one of which is correct I am assuming, hope you can help, regards, 7615sp.
