Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Flow Meter
- This topic has 8 replies, 3 voices, and was last updated 17 years, 7 months ago by
mjhservices.
August 29, 2008 at 4:42 pm #39081
mjhservices
ParticipantWhirlpool ADP4502/5 8511 504 15859
After filling a short while it stops and flashes 7 times which I beleive is the flow meter (correct me if wrong)
Can this be bought without changing the complete Can-measuring / water chamber as they call it, as the cost is rather high.Regards Mark
August 29, 2008 at 4:47 pm #261226Penguin45
ParticipantRe: Flow Meter
Nope, complete assembly. You can buy the reed switch from RS/Maplins and the like for pennies though……
August 29, 2008 at 5:05 pm #261227mjhservices
Penguin45 wrote:Nope, complete assembly. You can buy the reed switch from RS/Maplins and the like for pennies though……
1. Would this cure the 7 flashes?
2. What and where on the dishwasher is the “reed switch”Regards Mark
August 29, 2008 at 5:16 pm #261228Penguin45
Normal fault is oxidisation of the contact pads on the reed switch pcb. A good clean and a pinch of the connector usually sorts it. The reed switches themselves can fail, giving no signal when the water wheel spins.
August 29, 2008 at 5:23 pm #261229mjhservices
Penguin45 wrote:Normal fault is oxidisation of the contact pads on the reed switch pcb. A good clean and a pinch of the connector usually sorts it. The reed switches themselves can fail, giving no signal when the water wheel spins.
Thank you I shall check this.
Mark
August 29, 2008 at 6:33 pm #261230August 30, 2008 at 6:54 am #261231mjhservices
Martin114 wrote:I use reed switch part no. sw02762 from CPC
This swich is a different shape etc, how does this fit into the plastic water meter tank on the left hand side of the dishwasher?
Regards, Mark
August 30, 2008 at 8:05 am #261232Martin114
Hi Mark, I pull out the little pcb that houses the reed switch, de-solder the old and solder in the new. I also tin the contact strips with solder to bring them out a bit and make a tighter connection to the plug.
Cheers,
MartinAugust 30, 2008 at 10:09 am #261233mjhservices
Martin114 wrote:Hi Mark, I pull out the little pcb that houses the reed switch, de-solder the old and solder in the new. I also tin the contact strips with solder to bring them out a bit and make a tighter connection to the plug.
Cheers,
MartinThank you Martin for your reply and advise.
